Activity › Forums › VEGAS Pro › How to get proper audio level output when rendering in Vegas 5
  • How to get proper audio level output when rendering in Vegas 5
    Posted by Animeniac on January 4, 2006 at 12:44 am
    I’ve run into this problem – I set the audio levels to how I want them and when I playback the video in the project timeline, the audio sounds fine. However when I go to render it, the completed render’s audio comes out a very low volume. I’ve only tried this when rendering to MPEG-2.
    Is there a setting I’m not adjusting properly for output? I use the defaults set by the application. I’ve tried using audio in both MP3 as well as .WAV format with the same results.
    ~AnimeNiac
    Edward Troxel replied 20 years, 9 months ago 3 Members · 2 Replies
