Activity Forums Apple Final Cut Pro Legacy How to get .MTS files into FCP 6 from a hard drive (the card has already been erased)
  • How to get .MTS files into FCP 6 from a hard drive (the card has already been erased)
    Posted by Andy Tolbert on May 28, 2013 at 1:15 pm
    Someone mentioned log and transfer to me but I believe that only works with a reader (right?)and the card has already been wiped.
    Do i need to get software? Toast v 11? something like that? I know streamclip won’t do it. Need to get these in ASAP.
    AT
    Andy Tolbert replied 13 years, 3 months ago 3 Members · 5 Replies
  • Eric Strand
    May 28, 2013 at 3:27 pm
    Do you have the full structure of the card intact on the drive? If so you can still use L&T, just have to tell it to look on the drive. If not you can use ClipWrap, it rewraps or transcodes the clip, depending on what you choose.
    https://www.divergentmedia.com/clipwrap
  • Andy Tolbert
    May 28, 2013 at 5:13 pm
    Thanks! No they just copied the .mts files but I will let them know for the future…and thanks for the clipwrap 411!
  • Eric Strand
    May 28, 2013 at 5:54 pm
    You’re welcome.
  • Michael Gissing
    May 28, 2013 at 11:08 pm
    You should always convert from the hard drive backup, not the cards when using L&T. If you have to recapture for any reason, it will be looking for the card, not the backup. So do the original L&T from that backup.
    I always save the total card structure on two separate drives (both RAID 5) and do the L&T before erasing cards.
  • Andy Tolbert
    May 29, 2013 at 12:15 am
    Thanks so much. You and Eric have really helped me out here.
    AT
