Activity › Forums › Adobe Photoshop › How to get lines glow like this
  • Kevin Camin
    March 20, 2019 at 3:08 am
    For the middle glowing rectangle, you can do an inner glow if it’s a separate layer or just draw the inner glow. Then you can create the outer flow by duplicating the rectangle and coloring it lighter, blurring it, putting it in a screen or overlay mode and adjusting its opacity.
    For the outer lines, you can brighten or darken the lines with an adjustment layer and feather out a mask.
    I mocked it up for you. Hopefully you can look at each layer and figure it out.
    https://we.tl/t-0Qjg1Kd1IU
    Best regards,
    Kevin Camin
