how to get it from FCP to DVD under 3 days render?
Hi
What’s best quality, most efficient way to get our 85 min documentary out of FCP 6 to an SD DVD master?
Using 2008 model Mac Pro 3.0, 8GB RAM, I’m going from FCP to Compressor, via QT movie (current settings Pro Res) of Timeline, bring it into Compressor = NTSC, 16×9, 2 pass VBR best, 6.5 to 7.6 bit rate, GOP = IBBP closed, size 15, Frame Controls ON, resize filter = BEST, De-interlace = fast, Rate Conversion = Good…
I did a 2 minute test and it took an hour! And that was for a web-friendly 480 x 270 size. What’s it going to be at 720 x 405 (the 16 x 9 version) – 3 days? What to do? Should I print the timeline to tape and bring it to a post house and they can do better or what? I know if I turn frame controls to OFF it’ll speed up significantly, but then the FONTS/Text especially when over Black BG look horrible after compressed to 720 x 405.
Suggestions?
K
web.me.com/kbcv
