Activity Forums Apple Final Cut Pro Legacy how to get from card to deck?
  • how to get from card to deck?
    Posted by Cade Muhlig on May 24, 2007 at 2:34 am
    im hoping walter will respond to this, because his system and mine are pretty close.
    i want to output from final cut to my kona lh, to my m10u tape deck and not use print to tape. i want to use the kona cards realtime down conversion. but neither my tape deck or any dvd recorder have component input. i heard something about an aja breakout box would work?
    i have an audio setup that will work already.
    -cade
    Jeremy Garchow replied 19 years, 3 months ago 2 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    May 24, 2007 at 2:48 am
    What inputs do you have?
  • Cade Muhlig
    May 24, 2007 at 3:00 am
    good point,
    video or s-video
  • Jeremy Garchow
    May 24, 2007 at 3:06 am
    And firewire i take it.
    Two options, drop Hd sequence into Dv sequence, render and output.
    Use your KOna card by opening the control panel, change the analog out from component to either composite +YC. The y output of your component is the composite signal, or if you have a dual bnc to svideo adapter, use that for svideo. Set up the down convert by choosing the secondary format on the analog out and away you go.
    Jeremy
  • Cade Muhlig
    May 24, 2007 at 3:32 am
    wow, thats interesting…
    so would the dual bnc to s-video signal be better than the composite?
  • Jeremy Garchow
    May 24, 2007 at 3:34 am
    Yes. Looks like this:
    https://www.svideo.com/sv2bnc1.html
  • Cade Muhlig
    May 24, 2007 at 3:43 am
    behold, it works!
    it looks ok, but you say the bnc route is better? have you tried?
    thanks mucho
  • Cade Muhlig
    May 24, 2007 at 3:47 am
    i can tell with this way that the saturation and contrast is down a bit.
  • Jeremy Garchow
    May 24, 2007 at 4:04 am
    S-video is cleaner than composite. You can do it with a DVD p;ayer. Hook up a DVD player through composite, than S-Video and a/b your monitor. Wow, analog, haven’t talked about composite and S-video for a long while. Thanks for the memories!
