Activity › Forums › Apple Final Cut Pro Legacy › How to get footage back to normal after zoom in affected entire timeline. SOS
Posted by Chezgray on February 15, 2007 at 3:17 pmHi. I was told that when you double click on a specific shot, only that shot is affected when you zoom in. I think I worked on a shot after hitting the “F” key for match frame, and it seems that my entire project is now zoomed in. I’ve tried hitting Apple A to highlight the whole timeline and then reverse the change. I’ve tried changing individual shots that I see are at 200% I change them to 100%, but it doesn’t stick. I’ve also tried making changes through the motion tabs. Bottom line is that I have no idea what I’m doing. I need to get going on this project, and this snafu has me stuck. Any help you can give to get my project back to normal settings will be much appreciated. I need to zoom in on a few shots to crop out a drooping microphone, but having the rest of it zoomed in doesn’t work at all.
Thanks.
Don Greening replied 19 years, 7 months ago 5 Members · 12 Replies -
Delano Bryant
February 15, 2007 at 4:42 pmYou have to insert keyframes to set the out boundaries you want the effected video. YOu should be able to “highlight” clips in timeline then right click and change under settings. If you want delete that timeline and re-import your clips into it and make sure you use keyframes.
Is that the color red you want to use?
Don Greening
February 15, 2007 at 4:57 pmTry selecting all the clips at once that are zoomed in then right or control click on one of the selected clips. In the pop-up menu select “remove attributes.” Make sure “Basic Motion” is checked and then click OK. Try that and post back with the results. If that doesn’t make the changes ‘stick’ then there may be a problem with FCP’s preference files whcih is just a guess at this point.
– Don
“Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
Chezgray
February 15, 2007 at 5:02 pmWhen I tried going back to the original footage in the bin, it seemed that that footage was also affected and cropped. Is there any way to just get everything back to normal without using keyframes?
Thanks.
Don Greening
February 15, 2007 at 5:10 pmIf your source clips have been changed then drag them into the viewer window one by one. Click on the Motion tab. You’ll see a red X in the upper middle of the window. This is the reset button for that particualr clip. Click on it and that should get rid of all your changes. You’ll need to do that for each source clip.
– Don
Chezgray
February 15, 2007 at 5:56 pmHi Don
Thank you. I can’t believe that one little mistake makes such a headache that could take a long time to straighten out. Such is life. I will try what you suggest.
I have no idea how to update my profile. How do I do that?
Thanks. Donna Gray
David Bogie
February 15, 2007 at 6:11 pm> Hi. I was told that when you double click on a specific shot, only that shot is affected when you zoom in. I think I worked on a shot after hitting the “F” key for match frame, and it seems that my entire project is now zoomed in. I’ve tried hitting Apple A to highlight the whole timeline and then reverse the change. I’ve tried changing individual shots that I see are at 200% I change them to 100%, but it doesn’t stick. < This sounds like you have set the viewer and canvas to larger window sizes and not applied scaling to the clips. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
Nick Meyers
February 15, 2007 at 6:19 pmwhat bogiesan says.
fix this by going to the % pulldown menu top of both viewer and canvas and setting to “Fit to Window”
also learn this: SHIFT + Z
that’s the keyboard shortcut for fit to window.to do a proper zoom on an image,
turn on IMAGE & WIRE FRAME in the “view” menu in the CANVAS (to the right of the % menu)
select your clip in the timeline,
now you’ll see a wireframe in the canvas.
you need to grab a corner of the blue border and pull on that to increase scale.TIP: you may have to zoom the canvas out to be able to grab the blue border. (Select Canvas, Apple minus)
pop quiz: how do you get the canvas back to the correct size?nick
Chezgray
February 15, 2007 at 6:29 pmHi Nick
That sounds like great advice. Final cut pro often gets the better of me. I’m afraid I can’t answer your pop quiz about how to unzoom the canvas. Don’t know. Can you illuminate?
Thanks. Donna
Nick Meyers
February 15, 2007 at 6:34 pm“I’m afraid I can’t answer your pop quiz about how to unzoom the canvas”
yes you can!
(read my post again)
nick
Chezgray
February 15, 2007 at 7:14 pmWell, I think the answer to your pop quiz is select canvas Apple +
I know I should “read the freaking manual,” but when I get stuck like this it’s hard for me to find what I need there. I see that in my view menu, “window and wire fame” is checked off. How do you uncheck it. I’ve tried just clicking on it, and using Apple, shift, and contol click. Nothing works. Just when I think I’m getting this down, I get stumped on something that’s probably obvious to other people. I appreciate the help in getting my project back on track.
Thanks a lot. Donna
