Activity Forums Avid Media Composer How to get Fast Imports with single frame animations out of AE
  • How to get Fast Imports with single frame animations out of AE
    Posted by Chris Huggett on August 1, 2005 at 4:40 am
    Hi guys
    i have been testing the meridean codec as of late, and rendered some widescreen interlaced footage out of AE (RGB 0-255, PAL, 3:1 interlaced, Upperfield. 720×576 widescreen pix) and imported it into Avid, with the Import settings set to 601, non square, Upperfield, RGB, and use files resolution checked, and my footage flew in. I was so surprised when i saw it say fast import quicktime.
    I tried the same file with the same settings, but rendered as frames out of AE, and used the 3:1 progressive setting, imported into AVID as non-interlaced, and checked the “use files resolution” setting, but it did not come in as a fast import…..
    I then tried the export setting out of AE Meridian codec, 4:1s single field, same settings, but it would not render and popped up a warnimg “compressing frame of movie – QUicktime codec error”
    Im guessing the last one may be because my comp settings are wrong… any ideas if that is correct….
    Im happy i worked out the interlaced fast import setting, but i want to get the single frame fast import for our animations…
    I have the latest codecs for Avid Quicktime.
    Chris
    ttp://www.acclaim.tv
    Chris Huggett replied 20 years, 9 months ago 1 Member · 1 Reply
  • Chris Huggett
    August 2, 2005 at 9:12 am
    Hey guys
    i really need some advice on this….
    how can i take advantage of the fast import with this setting. I have used the 3:1 interlaced export setting and that took advantage of the fast import, but when i have used the 3:1 progressive in the same project, it doesn’t work.
    What can i be doing wrong?
    I dont know much about Avid, but all my work ends up being imported into one, and the compression time is taking too long when i import.
    Thanks for your time
    Chris
