Activity › Forums › Apple Final Cut Pro › How to get both subject and background to fade out together?
  • How to get both subject and background to fade out together?
    Posted by Greg Thompson on June 5, 2012 at 6:50 pm
    I’ve got a subject and a keyed out green screen. I’ve applied a background image and everything looks great. But when I apply “Fade To Color” on the subject and another “Fade To Color” on the background, the subject properly fades out but the background goes completely black on the first frame of the fade out (this happens even when I don’t apply any fade to the background at all and only fade the subject)
    How do I properly fade out both background and subject to black?
    Thank you.
    Greg Thompson replied 14 years, 3 months ago 3 Members · 4 Replies
  • Jason Brown
    June 5, 2012 at 7:21 pm
    Compound clip?
    Put color solid above and dissolve to solid?
  • Greg Thompson
    June 5, 2012 at 7:31 pm
    Why is it doing this?
  • Loren Risker
    June 5, 2012 at 9:03 pm
    Looks like you only have the fade on one of the elements, I agree that a compound clip is the easiest way to do it. Just select both, right click, make compound clip, then slap on a fade.
    OutOfFocus.TV – Music videos, docs, entertainment.
  • Greg Thompson
    June 5, 2012 at 11:39 pm
    Ok, thank you. That solved it. I wasn’t aware of how compound clips worked.
