Activity › Forums › Adobe Premiere Pro › How to get Boris Transitions to work in CS5?
  • How to get Boris Transitions to work in CS5?
    Posted by Bill Thomas on October 16, 2013 at 4:59 pm
    Hi all,
    Dumb question here:
    I’m trying out the Boris Final Effects plugins in CS5 and they installed correctly but they all showed up in the Effects folder and none in the Transitions folder.
    Although Boris Transitions show up in the effects folder and when I try to apply them between 2 clips, it always tries to apply to a single clip.
    Is there a reason that Boris Transitions don’t work like the native transitions?
    And if they don’t, how would I be able to use the Boris transitions between 2 clips?
    Thanks all…
    Bill
    Kevin Monahan replied 12 years, 11 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    October 16, 2013 at 5:08 pm
    I don’t think may effects in the market are used as native transitions (I think Boris’s makeshift AE replacement called Boris RED can do it).
    Generally you apply the transition to both clips, put clip 1 above clip 2 and overlap where they join slightly, then you keyframe the effect amount from 0 to 100 on the entering clip and 100 on the exiting clip.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Bill Thomas
    October 16, 2013 at 6:44 pm
    [Angelo Lorenzo] “I don’t think may effects in the market are used as native transitions (I think Boris’s makeshift AE replacement called Boris RED can do it).
    Generally you apply the transition to both clips, put clip 1 above clip 2 and overlap where they join slightly, then you keyframe the effect amount from 0 to 100 on the entering clip and 100 on the exiting clip.”
    Thanks Angelo!
  • Kevin Monahan
    October 21, 2013 at 8:42 pm
    Hi guys,
    In the upcoming release of Premiere Pro CC, some plug-in foundries will have transitions that will be in the transitions folder and can be applied in a single track as standard transitions. GenArts comes to mind.
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
