Activity Forums Blackmagic Design How to get a separate out put for key and fill using Black magic extreme HD card ?
  • How to get a separate out put for key and fill using Black magic extreme HD card ?
    Posted by Kiran Nataraj on August 9, 2011 at 3:05 pm
    checked the output,getting video out from both sd video 1 out and video2 out ports .
    video out 1 should give key and video 2 out should produce fill it seems.
    Downloaded api reference and c# samples from medialooks, haven’t found any material reg key,fill till now .
    Could you guys help me on this?
    warm regards,
    Kiran
    Kiran Nataraj replied 14 years, 8 months ago 2 Members · 4 Replies
  • Chuck Pullen
    September 6, 2011 at 3:03 pm
    Did you ever figure this out? I am getting ready to do the same thing?
    Chuck
  • Kiran Nataraj
    September 7, 2011 at 9:15 am
    Hey,
    Chuck,
    We tried so many times and couldn’t get this and in-case you are able to breakthrough kindly help us out on this
  • Chuck Pullen
    September 7, 2011 at 1:19 pm
    Tell me about your workflow. What program are you using to generate the Keys, what switcher are you using? I am using a Panasonic switcher and the process to create a key/fill assignment is quite extensive.
    Chuck
  • Kiran Nataraj
    September 12, 2011 at 4:20 pm
    Chuck
    checked the output,geting video out from both sd video 1 out and video2 out ports .
    video out 1 should give key and video 2 out should produce fill itseems.
    Downloaded api reference and c# samples from medialooks, havent found any material reg key,fill till now.
    We are attempting to do this in .Net and till now we have not used any switcher or mixer, but we downloaded the live key application from the black magic support website and nothing worked.
    Do you have any idea on this ?
    Thanks and regards,
    Kiran
