Activity Forums Zaxwerks How to freeze frame Invig Pro?
  • How to freeze frame Invig Pro?
    Posted by Navarro Parker on January 19, 2007 at 4:12 pm
    Is there anyway to get Invig Pro not to render every frame if there are no animated parameters? I notice that even if nothing is animated, Invig renders every frame (which leads to really long render times).
    Right now, I’m rendering out a still, importing it and then replacing my Invig layer with it.
    Is there a way to freeze the current view?
    Robin Remde replied 19 years, 8 months ago 2 Members · 1 Reply
  • Robin Remde
    January 19, 2007 at 6:47 pm
    You could drag the out point of the scene (the red marker at the top of the timeline) so that the rendered movie is only a couple of frames long, render it as a pict or targa sequence, and only import the first image…. that might work.
