Activity Forums Storage & Archiving How to format LTO-5 tapes using BRU PE (and leave them BRU-compatible)
  • How to format LTO-5 tapes using BRU PE (and leave them BRU-compatible)
    Posted by João Rebelo pinto on April 22, 2014 at 11:10 am
    Good morning, everyone (or afternoon, depending on your timezone).
    I have tried to format an LTO-5 before but unsuccessfully, since I am not LTO-savvy or terminal-savvy.
    I have tried to put this question through the support in the past but for some reason my ticket simply disappeared.
    I have some LTOs that I want to “recycle”, completely erasing the information I have inside and make them BRU-compatible.
    How would you propose I do this, and could you please provide a detailed explanation (step-by-step)? I would be very much appreciated.
    I have BRU PE version 3.0.2 (build 108), on a mac running 10.7.5, and I have an HP LTO-5 Ultrium 3000 tape drive.
    Any more information I could provide, let me know.
    PS: I guess this question could best be answered by TIM JONES, of TOLIS Group, but I don’t know how to tag him so he can see this… :/
    Pall Olafsson replied 11 years, 4 months ago 5 Members · 10 Replies
  • 10 Replies
  • Jorge Bernal
    April 24, 2014 at 5:13 pm
    The only thing you need to do is to go about your archive as usual.
    Once you are ready to go, when you hit the button a menu will come up asking whether you are appending (adding) or overwriting. Choose overwriting and whatever existed on that tape before will be gone.
    Jorge Bernal
    Editor
    http://www.bernal.tv
  • Tim Jones
    April 28, 2014 at 9:36 pm
    Hi Joao –
    No format required for BRU tapes. BRU uses the raw tape layer. Just pop the tape into the drive and tell BRU PE to write (overwrite a new tape since you can’t append to it 🙂 ).
    Tim
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • John Sellman
    December 4, 2014 at 3:10 pm
    Every time I try to backup the tape ejects and says that it’s full, even when I check the overwrite button.
  • Tim Jones
    December 4, 2014 at 5:34 pm
    You should definitely open a support ticket at https://support.bru.com. The team will get you sorted very quickly.
    Tim
    Tim Jones
    https://www.tolisgroup.com
  • Pall Olafsson
    April 16, 2015 at 11:28 am
    Hi, I have a similar problem… when Archiving I check to erase old information on the tape but it ignore it and ask for another tape, this tape is full. Did you have any luck with this?
  • Pall Olafsson
    April 16, 2015 at 11:31 am
    Did you get any solution?
  • Tim Jones
    April 16, 2015 at 3:36 pm
    What brand of tape drive are you using?
    Tim
    Tim Jones
  • Pall Olafsson
    April 16, 2015 at 4:18 pm
    Hi, I’m using
    HP StoreEver LTO-5 Ultrium 3000 SAS External Tape Drive
    https://h30094.https://www3.hp.com/product/sku/10240361
    I tried a different cable (the one I was using was used for a LTO 4 tape drive)
    and it seems to be working… is that possible that it was the cable?
  • Tim Jones
    April 16, 2015 at 4:33 pm
    Absolutely. We actually have custom 1 to 1 and 1 to 4 cables built for our solutions because we found that the generic cables available in the market were too unpredictable from a quality standpoint. They really start to demonstrate issues when we started driving LTO-6 at full speeds (180MB/sec ±).
    I’m glad that you got that sorted.
    Tim
    Tim Jones
  • Pall Olafsson
    April 16, 2015 at 4:44 pm
    I’m doing some tests to make sure this is working as it should, but I think this sorted out the problem.
    I’ll post you to let you know the final result 🙂
    Thank’s for the help!
