Activity › Forums › Apple Final Cut Pro Legacy › How to flush Render Files folder
  • How to flush Render Files folder
    Posted by Margus Voll on April 11, 2008 at 3:38 pm
    Hi.
    I have alot of render files in final cut Pro Doc folder.
    Is there eny way to “safely” flush them?
    With one project i did delete them and later on this same project kept screaming for missing files or do i just undrestood it wrong ?
    I used to use premiere and there you just delete such files and everything works perfectly just you might have to render some sequences again if needed.
    Eny ideas?
    Margus
    https://iconstudios.eu
    Chris Borjis replied 18 years, 5 months ago 3 Members · 2 Replies
  • Matthew Nelson
    April 11, 2008 at 4:51 pm
    Tools/Render Manager
    You can delete render files by project/sequence as well as flush the undo.
    Matt
  • Chris Borjis
    April 11, 2008 at 6:34 pm
    when I’m not capturing I always set my scratch
    disk on a temp folder on the disk array.
    you can see in there folder names that match
    your project, the render files can easily be
    moved and dumped to the trash from there.
