Activity Forums Sony Cameras How to fix problems importing MP4 (SONY EX3) and MXF (C300) into Premiere! Finally!!!!!
  • Ian Cook
    April 30, 2014 at 3:33 pm
    Unless you are using a very old version of Premiere it should take EX .mp4s and XDCAM .mxfs natively. I cannot speak for Canon HD422 files but Sony XDCAM and EX files do not require plugins in CS5, CS6 or CC unless they are QuickTime wrapped and being read on a Windows system.
    Go with whatever works but again, you should not need anything besides Premiere unless it is very old or the files have been rewrapped for FCP.
  • Juaco Carriquiry
    April 30, 2014 at 3:45 pm
    Ha! Thanks for your comment Ian! Actually, while I was doing research about this I read a lot of your comments and it was very helpful at the moment! so thanks!
    I know that “in theory” it should take EX .mp4 and .mxfs, but in my case (and many others I found around forums) for some reason it doesn’t. I just found a solution but I’m not exactly sure whats the problem.
    Thanks again
    Juaco Carriquiry
    Audiovisual Producer
  • Clint Fleckenstein
    April 30, 2014 at 5:48 pm
    I’ve been bringing in XDCAM EX and Canon files natively with Premiere Pro since CS5.5.
    Cf
