Activity Forums VEGAS Pro How to fix frame slip in original footage
  • How to fix frame slip in original footage
    Posted by Nathan Miller on April 29, 2018 at 3:55 pm
    Not sure if “frame slip” is the correct term of art to describe the problem. I’ve attached screen shots showing the single frame that is affected. Second picture shows the artifact.
    Running Vegas Pro 15 and have the Boris Continuum Addin.
    Nathan Miller replied 8 years, 4 months ago 2 Members · 8 Replies
  • 8 Replies
  • Francois Pénzes
    May 1, 2018 at 10:18 am
    Hi Nathan
    By the looks of it, that may be the blanking interval from what looks like interlaced video.
    What is your source material from ?
    MediaInfo on your original clip ?
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 14
    \’\’When the cutting stops, the editing begins…\’\’
  • Nathan Miller
    May 1, 2018 at 10:37 am
    Original footage was shot 30 years ago on VHS and then edited to a 3/4 master. That tape was then dubbed to DVD and imported into Vegas.
    I was wrong, the issue happens for about 5 frames and you can see the frame move up as in a vertical scroll problem.
    If there’s a better solution, I’d love to hear about it. What I’ve done is to simply take a still image of the footage just before the problem and replace the defective video with that still. You can still see an anomoly during playback, but it’s less distracting than the original problem.
    Nathan
  • Francois Pénzes
    May 2, 2018 at 1:20 am
    Hi Nathan
    Are the black bars visible on the DVD version ? If so, there is not much you can do about it short of editing out the affected frames.
    Is that the case ?
    Cheers !
    Vegas Pro 14
  • Nathan Miller
    May 2, 2018 at 6:06 pm
    That is the case. So the solution I have in place is what I’ll need to live with.
    Separate/(sort of) question.
    Are there are native/addins to Sony Vegas Pro that can actually enhance old, crappy footage?
    I’m thinking (and I know it’s not apples to apples) of what I can do with digital photography enhancement today.
    I would assume that with original VHS footage it’s garbage in – garbage out, but on the off chance you know of something that breaks that rule, I’d love to hear about it.
    Thanks for your input!
    Nathan
  • Francois Pénzes
    May 4, 2018 at 12:26 am
    Hi Nathan
    Try the eval version of NeatVideo
    https://www.neatvideo.com/
    Works wonders for me and a whole lot of people here.
    Cheers !
    Vegas Pro 14
  • Nathan Miller
    May 5, 2018 at 1:43 pm
    Thanks for the suggestion. Tool looks like it does a fantastic job of removing noise.
    My problem is that there’s really not a lot of noise, it’s just low resolution that is now third generation.
  • Francois Pénzes
    May 5, 2018 at 8:44 pm
    Hi Nathan
    Well, unless you can spare mega gazillion dollars on very expensive professional software, with trained tech/operator, the best you can hope for when you have multi generation footage is to clean out the noise.
    Cheers !
    Vegas Pro 14
  • Nathan Miller
    May 6, 2018 at 11:30 pm
    No budget for that.
    Thanks for all the assistance!
    Nathan
