Activity Forums Adobe After Effects How to fix frame rate to mask path?!
  • How to fix frame rate to mask path?!
    Posted by Metodi Petrov on October 6, 2008 at 12:21 am
    Hello,
    I got the next issue:
    I’m cutting out an image for a rotoscoping since two days, and although I was absolutely sure I checked it before, the problem is here:
    import my 25fps footage and work into 30fps composition and create a lot of precise masks.
    now, if I try to change the frame rate,the masks are blow over…
    Any idea how to fix this, whitout remaking it again?!
    I’m editing a music video, so I need the sync…
    Thanks in advance!
    Metodi Petrov replied 17 years, 11 months ago 24,690 Members · 1 Reply
  • Metodi Petrov
    October 6, 2008 at 9:01 pm
    Thanks for the answear,
    probably I will re-do it manualy,
    Greetings!
