Activity Forums Apple Final Cut Pro Legacy How to fix an edit which has multiple frame rates
  • How to fix an edit which has multiple frame rates
    Posted by Randal Plunkett on December 24, 2011 at 8:05 pm
    Hi there, I signed onto a film as an editor and before the production started I gave the producer my preferred settings for them to shoot on. I asked them since they were shooting on canon dslrs, they were to shoot 25 frames, Pal format. I finished the rough cut of the film. So I decided to put all of it on a single time line since I edited till then scene by scene. When I put it on the timeline, things popped out of sync!!! After reviewing the footage with a tooth comb so to speak, I discovered that the idiots decided to shoot parts of the film in 23.97 frames rather then just 25 frames through out . Now after some rather feeble attempts to fix it by just clicking slip into sync button etc I have given up as it does not work. Please some one tell me that I dont have to start over and go back and reconvert all the bad footage again!!!!!
    Joseph Hung replied 14 years, 9 months ago 2 Members · 3 Replies
  • Randal Plunkett
    December 24, 2011 at 8:15 pm
    Thanks alot Dave for answering my question so fast, do you think if I do all that I can just simply try and retach the files on the timeline? or do you think it will be a mess and things will go off sync still
  • Randal Plunkett
    December 24, 2011 at 10:34 pm
    Thanks Dave your a star, I l try and do that
  • Joseph Hung
    December 25, 2011 at 5:42 am
    If there is sync sound, this might work to get the audio to sound right. Do a test clip and see if it helps.
    https://philipbloom.net/2009/05/30/how-to-convert-canon-5dmk2-footage-from-30p-to-24p/
    It worked for me when I shot on the 5D way back when before the firmware patch for 24p. It’s a bit convoluted, but worked.
    http://www.tulpapictures.com
    Twitter: @tulpapictures
    Facebook: http://www.facebook.com/tulpapictures
    Mac 2.66 GHz Quad Intel Xeon
    OSX 10.6.8
    FCS2
    CS5
    8GB RAM
    ProAvio 8TB RAID 5 Dual Mini-SAS
    Blackmagic Intensity Pro
    ATI Radeon X1900
    RocketRAID 4322 via dual MiniSAS
    Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
