Activity Forums Adobe Encore DVD How to fix Adobe Encore CS3 Crash ! ! ! READ
  • How to fix Adobe Encore CS3 Crash ! ! ! READ
    Posted by Rubens Carrilho on August 6, 2007 at 4:21 pm
    The problem with Adobe Encore CS3 can be fixed just putting a blank dvd media in the drive(s).
    I put a blank DVD media in my dvd drives and the startup problems stoped…. but if I remove the media, problem backs again.
    Sorry my English
    Rubens Carrilho
    Computer Graphics Designer
    Benoit Dorion replied 16 years, 7 months ago 5 Members · 5 Replies
  • Abel Del
    June 2, 2008 at 1:31 am
    Hi there!, I tried to load a cd/dvd on the drive…did not work!….
    After a couples of days I finally hit the jackpot! ..here is how fix the Adobe Encore Cs3 Crash at the beginning..
    The Issue was the Windows CD/DVD ASPI drivers for my DVD/CDs drive/s. yes!!!!! encore get stuck on the splash /loading screen when is displaying the “Come for the blu-ray, stay for the flash”.
    so here is the fix that worked for me:
    Before you try anything else, give the latest drivers (version 4.71) from Adaptec a try. They are supposed to work under 98/ME/NT/2K/XP and don’t care if you don’t have an Adaptec SCSI card installed.
    https://download.adaptec.com/software_pc/aspi/aspi_471a2.exe
    The first thing to check is to make sure that you have a fully functional set of driver files. Adaptec has produced a tool called ASPICHK which will tell you all about the health and version numbers of the drivers on your system. when you unzipped the files inside there is a tool called “aspichk.exe”.
    then if you are running XP just double clink on the “aspiinst.exe”
    , reboot your system and done!!! to ensure that the you new drivers are installed run again the “aspichk.exe”.
    hope this helps!!! it worked for me like a charm. after trying everything. Adobe Encore CS3 load fast as ever!!! SWEEEET!!!!
    cheers.
    Abel
  • Eric Wazirali
    June 6, 2008 at 5:55 am
    Hello guys, Please help me with this. I have Vista 64bit with 4gig ram. When i try to build DVD its crash on me . Please help me this is just driving me crazy. I have lot of work in panding. Here is the error
    This is the error code if it will provide any help.
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: Adobe Encore.exe
    Application Version: 3.0.1.8
    Application Timestamp: 46cf7628
    Fault Module Name: Adobe Encore.exe
    Fault Module Version: 3.0.1.8
    Fault Module Timestamp: 46cf7628
    Exception Code: c0000005
    Exception Offset: 003fa73c
    OS Version: 6.0.6001.2.1.0.768.3
    Locale ID: 1033
    Additional Information 1: fd00
    Additional Information 2: ea6f5fe8924aaa756324d57f87834160
    Additional Information 3: fd00
    Additional Information 4: ea6f5fe8924aaa756324d57f87834160
    Read our privacy statement:
    https://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
  • Joe Bowden
    June 6, 2008 at 6:31 pm
    Encore CS3 is not supported on Windows Vista 64 systems.
  • Eric Wazirali
    June 6, 2008 at 6:45 pm
    Hello, But it worked before. Its been working fine. I burned DVD before on this computer. And thanks for your help.
    Eric
  • Benoit Dorion
    February 22, 2010 at 12:43 pm
    Have you ever gotten this to work? I’m having the same issue and I also have Vista 64. I’m wondering if I should just get CS4 and open up my CS3 project in there and build it.
