Activity Forums Adobe After Effects Expressions How to find the index of a nested comp in it’s parent comp?
  • How to find the index of a nested comp in it’s parent comp?
    Posted by Carey Pagan on June 23, 2017 at 8:38 am
    I want to create an expression on a layer of a comp, that references the comp’s index inside the parent comp.
    Something like
    index = comp(“Parent Comp”).thisLayer.index
    is there a way?
    Dan Ebberts replied 9 years, 2 months ago 3 Members · 3 Replies
  • James Ronan
    June 23, 2017 at 8:51 am
    Almost!
    index = comp(“Parent Comp”).layer(“Child Comp”).index;
    Replace Child Comp with whatever your precomp is named.
  • Carey Pagan
    June 24, 2017 at 5:46 am
    Yeah I knew it could be referenced by name but there are more than 50 instances of the same pre comp so I really wanted a way to have their expressions reference the index of that particular instance of the pre comp inside it’s parent comp.
    Is there any other way to get a reference to ‘self’ like in c?
  • Dan Ebberts
    June 24, 2017 at 6:32 am
    There’s no way to do that. Otherwise, you could have the same precomp rendering differently in different layer instances, which can’t happen.
    Dan
