Activity Forums Adobe Premiere Pro How to find master clip from subclip pproCS5
  • How to find master clip from subclip pproCS5
    Posted by Gints Apsīts on January 7, 2011 at 8:31 am
    im looking for some easy way to extend my subclip.
    so i trying to find master clip from subclip pproCS5?
    only way i found is to look at subclip properties in file path for original masterclip name, then search it in project. but that’s a bit crazy for big project.
    any idea?
    thanks.
    Alex Udell replied 15 years, 8 months ago 2 Members · 1 Reply
  • Alex Udell
    January 7, 2011 at 3:11 pm
    You realize that you can still access the parent file frames from a Sub-clip? so maybe this is not necessary?
    “Adjust media start and end times of a subclip
    Select the subclip in the Project panel.
    Choose Clip > Edit Subclip.
    Edit the Subclip Start and End timecode fields.”
    does that help?
    Alex
