Activity Forums Maxon Cinema 4D how to filet the edge of a sliced cylinder?
  • how to filet the edge of a sliced cylinder?
    Posted by Ryan Fannon on September 8, 2008 at 3:41 pm
    I have a cylinder with the slice tool applied to it. the outer edge of the cylinder is already set to filet edge. i want to filet/chamfer the inner edges of the slice. what is the best way to do it?
    Brian Jones replied 18 years ago 2 Members · 1 Reply
  • Brian Jones
    September 9, 2008 at 4:03 am
    Assuming it’s Slice checked in the Slice tab of the Cylinder object and not the Slice option of the Knife Tool, you would want to make it editable, select the edges you want to chamfer and use the Bevel Tool. That will give you limited room to chamfer because the top of the cylinder is constructed of ‘pie wedges’. Otherwise I’d try making the cylinder from a cube in a hypernurb and make cuts where needed to get the right shape
