Activity › Forums › Adobe After Effects › How to fade in an image
Posted by Angga Putra on March 18, 2014 at 12:00 pmHello there.
I want to make an image to fill a screen and that was easy, but the thing is that I want another image to fade in. Is that possible?
Angga Putra replied 12 years, 6 months ago 2 Members · 2 Replies -
John Cuevas
March 18, 2014 at 1:18 pmDrop the next image into the compostion, press “T” to bring up the opacity settings, move the CTI(current time indicator) to where you want the fade to start, change the opacity to 0% and press the stopwatch to set a keyframe. Move the CTI to where you want the fade to end and change the opacity to 100%
This is as basic as it gets, and that you don’t know this indicates you would really benefit from Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)—lot of great information and free learning there that will teach you the basics of AE.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Angga Putra
March 19, 2014 at 1:26 amThanks to you guys. I already knew the Opacity manipulation but I thought it only works for videos only.
Thanks.
