Activity › Forums › Boris FX Particle Illusion › How to extend the life of a logo?
Posted by Charlie Chang on January 29, 2006 at 2:53 amI am using the Ring Converge logo. The problem I have is that the logo disapear after frame 110. How do I keep the logo appear longer? For example, after the logo appears I want the logo to stay like 4 seconds then shrink back. How do I achieve this? Thanks in advance.
Charlie Chang replied 20 years, 7 months ago 2 Members · 6 Replies -
Elvis Deane
January 29, 2006 at 5:35 amThe simplest way to do it is to copy and paste a new version of the logo at frame 1. Right-click on it in the stage and convert it to a point emitter. Now the particles will just fly up instead of coming in from all sides. Reduce the Velocity graph to 0, and crank up the Life to about 200%.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures -
Charlie Chang
January 29, 2006 at 6:14 amWell, I gave it a try…it does extend to about 10 or 20 frames but not long enough. Anyway to make it longer?
Elvis Deane
January 29, 2006 at 6:24 amThe more you increase the Life graph, the longer the particles will stay on the stage. So just push that past 200, until you get the length you need.
You’ll have to make two more changes if you push it much more than 200%. In the duplicate emitter you made, reset the Size over Life graph, and increase the topmost Size graph to 200%.
Elvis Deane!
