Activity › Forums › Apple Final Cut Pro Legacy › How to extend only one clip at edit point
  • How to extend only one clip at edit point
    Posted by Naveen Mallikarjuna on February 3, 2010 at 9:32 pm
    So if two clips are on the timeline, butted up next to each other, and you hit “V”, it selects the edit. If you then use the “>” or “<" it does a rolling edit, trimming off the piece of one clip and adding to the next. But what if you only want one clip to change? If Clip A and Clip B are next to each other, I want to select the end of Clip A and extend it by 5 frames. I DON'T want to shorten Clip B at the same time. I just want to extend Clip A, and push Clip B (intact), down the timeline by 5 frames. Is there an easy way to do this? Thanks!
    Naveen Mallikarjuna replied 16 years, 8 months ago 2 Members · 2 Replies
  • Tom Wolsky
    February 3, 2010 at 10:26 pm
    This is called a ripple edit. Press the U key till the incoming side of the edit is selected. Type 5 and press enter or return. There are other ways and tools to do this. I’d suggest reading a good book or getting a training DVD.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Naveen Mallikarjuna
    February 3, 2010 at 11:04 pm
    Thanks! I’ve been using Lynda.com, but must have somehow missed it. :p
    Naveen
    contact@naveenmedia.com
    http://www.naveenmedia.com
