Activity Forums Adobe Premiere Pro how to export this specs?
  • how to export this specs?
    Posted by cesar steven on September 19, 2020 at 5:59 am
    Hello community, does anyone have any idea how to export premiere according to these specifications?
    Container : MOV
    Video
    Format : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Bit rate mode : Constant
    Bit rate : 30.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Original scan type : Interlaced
    Scan order : Upper Field
    Audio
    Format : AAC
    Format profile : LC
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Samplerate : 48.0kHz
    Chris Wright replied 6 years ago 4 Members · 3 Replies
  • Shane Ross
    September 19, 2020 at 10:31 pm
    Advanced Video Codec…is that AVCHD? They want something delivered AS AVCHD? Not sure you can do that…that’s acquisition only, AFAIK. Can you verify the codec?
  • Ann Bens
    September 21, 2020 at 10:41 pm
    Could export H.264 and change extension to mov. Timeline needs to be interlaced.
  • Chris Wright
    September 21, 2020 at 11:47 pm
    H.264 and AVC mean the same thing. CABAC is only supported in the Main and higher profiles (but not the Base or extended profile).
    Adobe Media Encoder uses this entropy encoding by default with the right profile selected.
    Just select each option in Adobe Media Encoder.
