Activity › Forums › Apple Motion › how to export PAL anamorphic to animation codec
  • how to export PAL anamorphic to animation codec
    Posted by Marc Müller on May 6, 2009 at 3:36 pm
    Hi there outside
    I try to export from Motion PAL anamorphic to Animation codec, ’cause I need an Alpha Channel . The result is always an Animation Movie but 5:4 instead 16:9. In the specifications for Animation, I don’t see the possibility to check 16:9.
    thanks for help
    Carsten Orlt replied 17 years, 4 months ago 2 Members · 1 Reply
  • Carsten Orlt
    May 6, 2009 at 11:14 pm
    First thing to understand is that SD (standard definition) PAL is always 720×576 which is just by the pixel count 4×3 aspect ratio.
    How to we get the 16×9 aspect ratio images out of that without changing the pixel count. Simple, just define each pixel as NOT square and I can then create a 16×9 picture with a 4×3 pixel count = PAL SD anamorphic. The pixel count for PAL SD with SQUARE pixels is 1024×576.
    Animation codec (or any codec for that matter) doesn’t care if your pixels are square, anamorphic, round, triangle… A pixel for the codec is just a bunch of numbers. The only reason some codecs have the 16×9 option is to tell the software that uses it that it’s pixels are supposed to be interpreted as anamorphic shaped.
    So you can export from Motion as animation 720×576 and when you open this clip in FCP make sure to tell FCP that this clip is 16×9 and it will display it accordingly.
    Hope all this makes some sense (if anybody disputes anything please correct me as I’m not a technician by trade)
    Best
    Carsten
