Activity › Forums › Adobe After Effects › How to export out of AE a still frame or video while keeping the background transparent?
  • How to export out of AE a still frame or video while keeping the background transparent?
    Posted by Josh J. johnson on August 9, 2007 at 1:47 pm
    Everytime I export like a frame or picture my background is always black or brown never just transparent? What am I doing wrong?
    thanks
    Josh J. johnson replied 19 years, 1 month ago 2 Members · 3 Replies
  • Trent Armstrong
    August 9, 2007 at 2:40 pm
    One option is to do a Save Frame As… and use the Photoshop template. If there is no background in your composition, an alpha channel will be saved in the file. You should just make sure that your output template has RGB+ALPHA selected instead of just RGB.
    I usually do a TIFF with Alpha, but that is not necessary.
    Save Frame As… is located in the Composition Menu in the Menu Bar.
    I hope this helps!
    Trent
  • Josh J. johnson
    August 9, 2007 at 2:51 pm
    Yep I just figured it out but thanks for the reply!
  • Josh J. johnson
    August 9, 2007 at 3:10 pm
    I guess my problem wasn’t AE it is exporting the image/mov with an alpha and having the program I export it into reconize the alpha such as photoshop.
