Activity › Forums › Adobe After Effects › How to export only the rectangle tool on a tracker?
Posted by Kilian Figueras on April 7, 2018 at 6:41 amHi,
I have traced a person doing a lecture that he is moving around the scene. I want to export a video only of the rectangle tool tracked, is there a way to do that?
TIA
kilian
Kilian Figueras replied 8 years, 5 months ago 2 Members · 6 Replies -
Steve Bentley
April 7, 2018 at 7:44 amHi Kilian,
Can you say that another way, I’m not sure what you are after. -
Kilian Figueras
April 7, 2018 at 4:21 pm -
Steve Bentley
April 7, 2018 at 6:30 pmOr if you just want the one frame change your comp size (CNTrL/K) to match the size of the mask and center the image (with its mask following along). Then choose Composition/SaveasFrame and pick your output format.
Kilian Figueras
April 8, 2018 at 10:26 amI need all the video as he is speaking so one frame is not the solution, thanks
Kilian Figueras
April 8, 2018 at 10:28 amThat is exacting what I need.
I’m trying it with warp stabilize but I am not able to put the guy on the same place.
Any suggestion?Thanks!
