Activity Forums Apple Final Cut Pro Legacy How To: Export Low Rez clips from Hi Rez Timeline
  • How To: Export Low Rez clips from Hi Rez Timeline
    Posted by Deejaysham on June 10, 2007 at 3:17 am
    So I’d like to take my FCP project that has a bunch of digitized DV clips and export a version of the project, converting all the clips to lower rez video files… like offline video quality.
    Is there a way to just choose File:Export:Low Rez Project?
    Obviously that’s not the way, but how would I go about getting a duplicate project and low-rez duplicate video files so I can fit more on my disk and then move back to my high-rez clips for the final edit?
    Jerry Hofmann replied 19 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 10, 2007 at 2:51 pm
    Select everything in your Browser, then control click on one item to pull open the media manager.
    From there select recompress, OfflineRT as the codec, a destination and also select create new project file… will do exactly what you want to do.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
