Activity › Forums › Maxon Cinema 4D › How to export for 360º panorama
  • Adam Trachtenberg
    November 11, 2011 at 5:55 pm
    Here’s what it looks like to me:
    1. Add a VRay camera tag to your camera and set the projection to spherical;
    2. In VRay render settings, VRay Camera tab, set type to spherical, check the override FOV box, and set the FOV to 360.
    I think that’s it. Of course you have to set the appropriate output dimensions.
  • David Dinis
    November 14, 2011 at 1:40 pm
    I’ve tried that, adding a vray physical camera tag to the “normal” camera. I also adjusted aspect ratio to be the correct 2 to 1 and 6000 by 3000 pixels. However, the output is completely twisted, the “horizon” isn’t straight. Also, how can you be sure you’re rendering with vray when you export ?
  • Adam Trachtenberg
    November 14, 2011 at 4:42 pm
    Do you have the camera parallel to the ground? If not the horizon will be distorted just as it would be if your were shooting a physical panorama.
    If you have VRay Render selected in the render settings then that’s what will be output when you save the file.
    It does work!
  • David Dinis
    November 15, 2011 at 12:31 pm
    Thank you, that was certainly part of the problem. Also I had to try using lights because I guess my exposure was always very low, resulting in black frames. Again, thanks !
  • Adam Trachtenberg
    November 15, 2011 at 3:18 pm
    Yeah, that’s a tricky part about VRay: light falloff is tied to the scale of your scene.
  • Idafe Hernández plata
    November 13, 2012 at 3:53 pm
    Hello! I’m making a spherical scene with Cinema4D R12 that I want to export to After Effects but in my Vray Physical Camera-Projection I have not the option “Spherical”. Do you know why? How could I solve this problem?
  • Adam Trachtenberg
    November 13, 2012 at 9:11 pm
    You’ll find the parameter in the VRay Render settings, in the VRay Camera Tab. Set the type to spherical, check the override FOV box, and set the FOV to 360 degrees.
  • Glendon Tingson
    June 27, 2015 at 7:58 am
    Good Day Sir, I have a problem also with these, i need to create panorama in C4D with my projects, i create 7 cameras the problem i think its the camera angles or settings, please help me. Thank you
