Activity › Forums › Adobe Premiere Pro › How to export a film with a 5.1 mix from Premiere Pro?
  • How to export a film with a 5.1 mix from Premiere Pro?
    Posted by Pat Tremblay on February 28, 2016 at 6:24 am
    I’m trying to export a film with a 5.1 mix from Premiere Pro CS6 and have barely found any relevant info on the whole internet it seems…
    If someone could answer all my various questions it’d be much appreciated!!!
    I have received from my sound guy 7 files (C, L, R, LFE, Ls, Rs) and a poly mix containing all. I figured it’d be easier using the later, but Premiere gives me this error as I try to import the file: “the file could not be opened because of a header error“…
    From my understanding, I have to create a new sequence and choose (in Audio Tracks options) the 5.1 mix. But then do I have to assign each track as mono, assuming I have no choice to use those now (or whichever other choice)?
    Then I place each track on the timeline, but I only have one track where it’s written 5.1 and it’s for the master one… I wonder why it’s noted as such if I can’t put any other file in it…
    Then, it seems easy to position of the tracks with the black dot according to their logic place. BUT I have no idea where to put the LFE though, where should it go?
    Then if I try to export after, the only option that seems to support 5.1 audio is a wmv file, which is obviously not how I want my master to be. I was also trying to output a mpeg2 for blu-ray or h264 for blu-ray, but it doesn’t give me any 5.1 audio output options…
    So what video format can I choose that will give me a high rez video file while letting me out put a 5.1 mix out of that timeline?
    HP Elitebook 8760w laptop. Windows 7 – 64 bit. Intel(R) Core (TM) i7-2820QM CPU @ 2.30GHz 2.30GHz, 8GB RAM – Quadro 3000M Nvidia graphic card.
    Pat Tremblay replied 10 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
