Activity › Forums › Adobe After Effects › How to export a 3d tracked camera from AE to 3ds Max ?
  • How to export a 3d tracked camera from AE to 3ds Max ?
    Posted by Luiz Mihich on September 25, 2013 at 11:05 pm
    I know you can easily export a 3d camera tracked from a shot to Cinema 4d , but I
    can’t believe the excelent camera 3d track
    in AE cc doen’t export camera data in other formats, I use 3ds max 2014,for instance.
    I am aware there’s a script AE 3d , didn’t work for me,version is obsolete, any suggestion ?
    Luiz Mihich replied 13 years ago 2 Members · 2 Replies
  • Mathew Fuller
    September 26, 2013 at 3:56 am
    I use max with After FX all day every day. I cannot live without this plugin. You can send cameras, lights, and image planes back and forth… AE to MAX or MAX to AE.
    https://boomerlabs.com/cart/product.php?productid=8&cat=3&page=1
    You’re welcome,
    Mat
    My Work:
    https://www.morecompletefx.com
  • Luiz Mihich
    September 26, 2013 at 3:58 pm
    Hi Mathew, Thank you for your reply !
    I knew the plugin, but had the wrong idea about it, Does this plugin export a trackcamera created in After effects not
    in Max ? because I am not interested to use
    a camera created in Max but, instead ,take advantage of the tracking data obtained from a tracked shot in AE.
    I really need to be sure ,as the plugin is not cheap, and I am still intrigued about Why this is not part of AE exporting capabilities!
