Activity › Forums › Maxon Cinema 4D › How to even out rotation keyframes so that the speed stays the same throughout animation period?
  • How to even out rotation keyframes so that the speed stays the same throughout animation period?
    Posted by Hilary Tsai on June 1, 2019 at 7:05 pm
    I’ve got an object that is supposed to rotate at an even pace over the course of 60 seconds. I set a keyframe at 0 rotation, then went to the 60 second mark and set it at 2160 (so that it rotates 6 full times). However, I’m finding that the animation drags in the beginning and then picks up speed as it goes. I need the speed to remain even because it must loop seamlessly. Does anyone know how to resolve this issue and make the object rotate evenly throughout the composition?
    Brian Jones replied 7 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    June 1, 2019 at 8:15 pm
    Animation always comes in with ease in ease out by default since that’s more more natural . To do what you want you need to go to the F-curves and select the points and make the curve linear.
