Activity › Forums › Adobe After Effects › How to erase Rope From video Footage?
Posted by Mohammad Dashti on April 11, 2007 at 11:09 amHi
I shot from actor for my film with 1 Rope on his back. Now I want to know one or two technique for removing the rope from my footage?Mohammad Dashti replied 19 years, 5 months ago 7 Members · 9 Replies -
Jimmy Brunger
April 11, 2007 at 1:15 pmThe Cloning tool and lots of patience!
*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0 -
Mohammad Dashti
April 11, 2007 at 1:21 pmCan you Explain better
how to Clone my footage frame by frame?
Nicholas Toth
April 11, 2007 at 2:49 pmDepending on how thick the rope is you may be able to use
CC SIMPLE WIRE REMOVAL which is under your KEYING option.Its a pretty handy effect, but again its frame by frame.
If you aren’t comfortable using the clone/stamp tool, output a .film file, and use photoshop to stamp it out of each frame.
Danny Princz
April 11, 2007 at 3:48 pmthere may be an easier way, depending on whats in the shot.
w/o seeign the shot its impossible to tell, but if you have enough frames to come up with a clean plate, stabilize the shot, use some masks to roto the rope, it would be much better than trying to paint it out frame by frame… but i w/o seeing the shot its impossible to tell
who is that masked man…
Tclark
April 11, 2007 at 8:15 pmActully the easiest way would be to motion track the rope and then use CC Simple Wire Removel Tool. Hard to tell without seeing the shot.
Good Luck! -
Darby Edelen
April 11, 2007 at 10:05 pm[Nicholastoth] ”
Its a pretty handy effect, but again its frame by frame.”If the rope is perfectly straight (which it most likely is not, but I thought I’d mention this for people who face situations where it could be) you can motion track both ends of the rope and use that data for the CC Wire Removal. Speeds things up a bit, but it’ll probably still need tweaking by hand =)
Majorasshole
April 14, 2007 at 3:04 amThe Cycore “CC simple wire removal” plugin is easier than the cloner tool. It has a start and end point to the line and variables and sliders for how many pixels to remove and blend.
Mohammad Dashti
April 14, 2007 at 6:02 amHi
Thank you very much.
I understand and do my job very well with your helps.mohammad dashti
