Activity › Forums › Apple Final Cut Pro Legacy › How to enhance image detail?
  • How to enhance image detail?
    Posted by Ian Liuzzi-fedun on February 6, 2011 at 6:22 am
    Unfortunately I had the detail turned down on one of my cameras in my multicam shoot so it looks noticeably softer. While I can and probably will indeed soften the rest a bit more, there has to be something I can do other than use the sharpen filter built into FCP. I don’t know exactly what the detail on a camera does but I imagine it specifically speaks to possibly edge enhancing and the like. If you folks have any ideas of external filters (even if they aren’t free) I would be more than appreciative.
    Ian Liuzzi-fedun replied 15 years, 7 months ago 7 Members · 15 Replies
  • 15 Replies
  • David Eaks
    February 6, 2011 at 11:15 am
    You could try NEAT Video, it is a great tool to have at your disposal. Alongside it’s excellent noise reduction capabilities is the “Smart Sharpening” feature (Basic: one sharpness slider, or Advanced: adjustment of sharpness/noise by either- Channel (Y, Cr, Cb) or Frequency (High, Mid, Low)).
    There is a free demo, it only applies to 640×480 pixels, has a watermark and high-bitdepth rendering is disabled. Be sure to buy the Pro version if your working in HD.
    Here’s a link to the product feature’s page on their website-
    https://www.neatvideo.com/featuremap.html
    Be aware that LONG render times are involved!
  • Jerry Hofmann
    February 6, 2011 at 12:44 pm
    Without seeing the footage, it’s hard to say, but more than once I’ve been able to sharpen a tiny bit, and lower black levels on footage to make it acceptable.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jeff Greenberg
    February 6, 2011 at 5:20 pm
    How do the unsharp mask or sharpen filters look?
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • John Pale
    February 6, 2011 at 5:44 pm
    The sharpening in Compressor is more advanced than the tools in FCP
  • Ian Liuzzi-fedun
    February 6, 2011 at 6:18 pm
    I already own this filter. I never thought about using it for anything other than noise reduction.
  • Michael Gissing
    February 6, 2011 at 10:49 pm
    I have used the Lyric unsharpen mask filter in FCP and it is superior to the FCP filter. I have also played briefly with the sharpen filters in FX Factory and they have a lot of options for sharpening. The brief play was fairly impressive.
    So if you want to keep it inside FCP then try FX Factory or Lyric.
  • Ian Liuzzi-fedun
    February 7, 2011 at 12:06 am
    I have found a page with what appears to be every filter that FX Factory makes. Did you use any one of the sharpening filters specifically?
    https://www.noiseindustries.com/fxfactorypro/plugins/
  • Ian Liuzzi-fedun
    February 7, 2011 at 12:07 am
    I will look into this but I do not believe this will be extreme enough.
  • Ian Liuzzi-fedun
    Interesting option
  • Ian Liuzzi-fedun
    Too noisy and artificial.
