Activity Forums VEGAS Pro How to engage multiple track motions to work together?
  • How to engage multiple track motions to work together?
    Posted by Phil Loarie on October 5, 2012 at 7:38 pm
    I am using Vegas Pro 10(d), and would like to know if it is possible to set up several tracks so that their track motion is synchronized in such a way that if I change one track motion the others will proportionately make the same adjustments. An example might be to have a number of flat displays nested within each other and you want to create the effect of passing through each plane to the next display. I know this can be done manually by setting keyframes on each track but it would be so much easier if it could done with an automatic response on all the tracks engaged.
    -Phil
    John Rofrano replied 13 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
