Activity Forums Apple Final Cut Pro Legacy How to enable legacy codec in OS X 10.6.4
  • Rafael Amador
    January 17, 2011 at 2:38 pm
    Hi Tom,
    That’s very strrange.
    I have all the codecs available in all the QT applications.
    The pic from before was in QT.
    This is in MPGStreamclip:
    rafael
    http://www.nagavideo.com
  • David Roth weiss
    January 17, 2011 at 4:24 pm
    You’re just getting special treatment Rafael, cuz they’re not available any more on my machine.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Walter Soyka
    January 17, 2011 at 5:01 pm
    This must be done on the command line. Open Terminal, then copy and paste:
    qtdefaults write LegacyCodecsEnabled yes
    Walter Soyka
  • Rafael Amador
    January 17, 2011 at 5:04 pm
    [David Roth Weiss] “You’re just getting special treatment Rafael, cuz they’re not available any more on my machine.”
    QT Lao version?
    Whatever the issue, Apple can’t do this just like that.
    Unless..Apple is trying to discourage people for exporting to those old codecs. those codecs are – and must be for long – readeable, but not an export option on QT Player (still in MPGStreamclip and probably others).
    WHY me I have the option God?
    Probably because – against your wise advise, David – I installed SL on top of Leopard, so was something from the old QT 7 on the System.
    Any other guess?
    Rafael
  • David Roth weiss
    January 17, 2011 at 5:21 pm
    [Rafael Amador] “against your wise advise, David – I installed SL on top of Leopard, so was something from the old QT 7 on the System.
    I think you nailed it… That has to be the answer.
    David Roth Weiss
    Los Angeles
  • Walter Soyka
    January 17, 2011 at 5:29 pm
    I should add that I have tested and confirmed this on my workstation running 10.6.5, but it should work for 10.6.4 as well.
    Perhaps rebooting or relaunching QT-based applications after rewriting the preferences is necessary? If it still fails, what happens if you create a new user account and try with that?
    Walter Soyka
  • Jeremy Garchow
    January 17, 2011 at 6:32 pm
    What Mr. Soyka says.
    I did this a while ago on a Snow Leopard only machine (never had leopard on it).
    The terminal will set those codecs free.
    Jeremy
  • Rafael Amador
    January 17, 2011 at 7:34 pm
    Probably.
    I remember that after SL, I did installed QT 7 from the same disk.
    rafael
  • Gwen Sputore
    January 17, 2011 at 10:32 pm
    Yeah, saw it in MPEG Streamclip, but was hoping to export direct from FCP and AVID instead of exporting a native QT from the editing software and then exporting from MPEG Streamclip.
    zingarra
  • Gwen Sputore
    January 17, 2011 at 10:39 pm
    Hi, I’ve tried that and although it say’s they are now enabled I can’t see it as an option. In fact I can’t see what other codec it enables. I think it’s a placebo.
    zingarra
Page 2 of 3
