Activity Forums Apple Final Cut Pro Legacy How to edit timing of multiple clips
  • How to edit timing of multiple clips
    Posted by Tim Silva on February 4, 2009 at 8:08 pm
    What’s the trick to adjusting the timing of several still images in a sequence all at once. Say you have 10 images and you want them all to be the same length to sync to your soundtrack. How can you adjust them all simultaneously rather than one at a time?
    Thanks – Tim
    Tim Silva replied 17 years, 7 months ago 2 Members · 2 Replies
  • Rob Grauert
    February 4, 2009 at 10:54 pm
    Select all the still images when they are in the timeline, right click, choose “duration,” then make the adjustment
    Robert J. Grauert, Jr.
  • Tim Silva
    February 6, 2009 at 1:17 pm
    I knew it had to be something simple…
    Thanks so much.
    Tim
