Activity › Forums › Apple Final Cut Pro Legacy › How to edit this scence?
Posted by Advanced Spectrum on November 4, 2013 at 4:52 pmI have a video (see below) where at the 0:20 sec mark the camera is slowly panning to the left, the head of a man standing is slowly turning to the left and in the last second he winks.
I need to remove the wink and replace it with his non-winking eye from several frame ago.https://www.youtube.com/watch?v=xElRQ2krrvI
Between 1:25 and 1:30 I need to clean up the BBQ stained wall. Again, how to best do this?
I want to use Final Cut Pro X to do this. I would appreciate your replies. Thanks.Adam
Samuel Enblom replied 12 years, 10 months ago 7 Members · 14 Replies -
John Fishback
November 4, 2013 at 5:04 pmCheckout CoreMelt’s Slice X. It should be able to do what you want.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Advanced Spectrum
November 4, 2013 at 5:11 pmThis is a great pointer John! Any tools or techniques available within FCP X so I don’t have to purchase this plug-in?
Steve Eisen
November 4, 2013 at 5:42 pmYou never said you were looking for free. A lot of people worked very hard to create effects that can cover up video.
I would cut just before the wink.
That BBQ stained wall is going to need some serious rotoscoping. FCPX can not do that. As a shooter, I would have seen the stained wall and cleaned it before I shot. I’m gonna guess a re-shoot is not possible.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group -
Advanced Spectrum
November 4, 2013 at 5:52 pmWith due respect Steve, I never wanted anything for free. I own a licensed copy of FCP X and wanted to know if the fixes could be applied using it own tools rather than buying something else which of course might be the option I have to take if nothing else works.
Rshoot is not possible. I am just the editor. I was not involved with the shooting project.
Shane Ross
November 4, 2013 at 5:57 pmThis isn’t something you can accomplish in FCX…not convincingly.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Steve Eisen
November 4, 2013 at 6:21 pmThanks for supporting me and the clarification Shane
Steve Eisen
Vice President
Advanced Spectrum
November 4, 2013 at 6:24 pmOK great. Thanks you all. I will pass this project on to someone else.
Nick Meyers
November 5, 2013 at 12:13 amsorry, i haven’t looked at the video,
but a blink replacement would take about 5-10 minutes to do in FCP7if the head is turning it’s harder and may not be possible.
a WINK is not blink, and may not be possible as the face scrunches up too much.my process is:
take the last good frame of the eye before,
make a freeze, put it on V2
track the eye to the head by turning freeze to difference mode, and key framing,
use an eyebrow, say to track.do the same with the first good frame of the eye after the blink.
put it on V3
do an dissolve between the two freezes, from the before-blink to the after-blink frames.
usually i do an opacity keyframe rather than a dissolve.over this same duration dupe the V1 section on to V4
use an 8-point garbage matte around the eye area. (generally looks like a Zoro mask!)nick
Steve Eisen
November 5, 2013 at 1:17 amThe wink isn’t the problem!
Steve Eisen
Vice President
John Fishback
November 5, 2013 at 1:27 amYou might also do this in Motion. The eye is the challenge. The wall can be handled with a tracked matte, although, there’s some rotoscoping to be done with the person standing in front of it.
John
