Activity Forums Adobe After Effects How to edit motion path on shape transform for a position
  • How to edit motion path on shape transform for a position
    Posted by Doni Donovan on September 10, 2015 at 7:13 am
    This is my first thread.
    For every trick i am always found on this forum but now i cant found a solution to make a curve for a movement position.
    i have a shape layer and there are some ellipse on it.
    when i create 2 keyframes on Transform: Ellipse 1 – Position (this is not the layer transform), i cant see the line for edit the curve of the movement.
    the only way is i just try to copy a path to the position property so the movement is going curved now but i still cant see the curved line like on layer transform position.
    Tim Bentley replied 11 years ago 2 Members · 1 Reply
  • Tim Bentley
    September 10, 2015 at 9:46 pm
    As far as I know you can’t visualise the motion path of individual shapes, but you could create a null, link the shape’s x and y position to the null’s position and then animate the null.
    https://timbentley.info
