Activity Forums VEGAS Pro How to edit a bluray .m2ts file in sony vegas without re-rendering (losslessly)
  • How to edit a bluray .m2ts file in sony vegas without re-rendering (losslessly)
    Posted by Darius Sjolander on September 3, 2014 at 9:24 pm
    Hi I would like to edit a bluray .m2ts file in Sony Vegas 13 however when I add it to the project the sound does not import, just the picture. Also I want to render an edited version of the bluray video without any recompression/re-rendering or any loss or change of quality whatsoever. What is the best thing to do in terms of workflow?
    This is the details of the video:
    General
    Complete name : C:\Temp\BDMV\STREAM\00003.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 21.8 GiB
    Duration : 1h 27mn
    Overall bit rate mode : Variable
    Overall bit rate : 33.5 Mbps
    Maximum Overall bit rate : 48.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : 27
    Duration : 1h 33mn
    Bit rate mode : Variable
    Maximum bit rate : 35.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Menu ID : 1 (0x1)
    Format : DTS
    Format/Info : Digital Theater Systems
    Format profile : MA / Core
    Mode : 16
    Format settings, Endianness : Big
    Muxing mode : Stream extension
    Codec ID : 134
    Duration : 1h 33mn
    Bit rate : Unknown / 768 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossless / Lossy
    I would really appreciate any help
    Darius Sjolander replied 12 years ago 2 Members · 2 Replies
  • Chris King
    September 4, 2014 at 2:52 am
    The M2TS file type is a compressed output format, but not ideal for editing in NLE system. To solve those problems, the quick workaround is to transcode M2TS files to Sony Vegas natively supported formats (MPG/MOV are highly recommended). During the process, it may cause a little loss but can ignore as I’ve tried it.
  • Darius Sjolander
    September 4, 2014 at 6:31 pm
    Is transcoding really a quick workaround? Is there no way I can just open the .m2ts and also get the audio tracks to show since Sony vegas only opens the video, I don’t mind rendering the final edited output as .mp4 I just don’t want intermediate conversion steps. Thanks.
