Activity › Forums › Adobe Premiere Pro › How to easily export with same frame size/rate/ratio as sequence but just change the codec/wrapper?
  • How to easily export with same frame size/rate/ratio as sequence but just change the codec/wrapper?
    Posted by Christopher Travis on April 26, 2012 at 9:57 am
    Hello,
    I’ve been tinkering with Premiere and I’m wondering if anyone can show me the quickest way to export a movie from a sequence which is the same frame size, rate and aspect ratio of the sequence, but with a different codec/wrapper? When I check the “match sequence settings” button in the export window, it greys out the codec/format menu so I can only export in the same codec as the sequence. Do I really have to manually enter the frame size and aspect ratio every time I want to export a movie?
    Chris
    Ann Bens replied 14 years, 5 months ago 2 Members · 1 Reply
  • Ann Bens
    April 26, 2012 at 9:55 pm
    Once set (manually) make it into a preset.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
