Activity Forums Boris FX Particle Illusion How To Duplicate A Particle Type?
  • How To Duplicate A Particle Type?
    Posted by Chip Babbitt on August 16, 2006 at 7:35 pm
    In the Tutorial Disintegrate A Logo, at the end it says that you have to Duplicate the Squares Particle type a few times if adding Motion Blur. So…how do you duplicate it? What button? Anything?
    Alan Lorence replied 20 years, 1 month ago 2 Members · 1 Reply
  • Alan Lorence
    August 17, 2006 at 12:29 pm
    The easiest way is to open the properties dialog for this stage emitter, then select the particle type in the hierarchy and click the “add particle type” button below the hierarchy to make a copy of this particle type. You can do this a few times.
    Alan.
    wondertouch
