Activity › Forums › Adobe Premiere Pro › How to down convert HD to SD???
Posted by Mark Collins on September 30, 2010 at 10:20 pmI am using adobe premiere cs5
I have a HD video project that I want to down convert to SD.
Should I export it as HD, then size it down? Or should I export it directly from Pr5 as SD.Mark Collins
Ann Bens replied 15 years, 12 months ago 3 Members · 5 Replies -
Ann Bens
September 30, 2010 at 10:35 pmCS5 has improved significant when it comes to scaling down HD to SD
You can export directly to sd m2v with AME or go through DL and let Encore do the math. -
Mark Collins
September 30, 2010 at 11:07 pmThanks for the fast response. But sorry I don’t know what DL stands for. Could you help me?
MarkMark Collins
Eric Monroe
October 1, 2010 at 9:57 amMark,
once you are finished editing your video on the timeline, do the following.
go to “File” drop that down, choose “Export” (a flyout menu will come from there) choose “media”
the Export setting window will pop open
go to the “format” tab and drop it down, choose MPEG2-DVD
next one down is “preset” choose “NTSC Progressive Widescreen High Quality”
(I assume since you are down-converting HD it will be SD widescreen)
Next go to “output name” name it what you want and pick a location to save the file.
Next go down to the “video” tab (beside filters, multiplexer etc.) Scroll through the “video” tab and make sure that the Field order is set to progressive, and the pixel aspect ratio is set to widescreen 16:9
from there you can either export the file directly, or you could choose “queue” and send it into Media Encoder.
Once into Encore, you will need to go to the project panel and right click and import as “timeline” when the window pops open choose both the .m2v (hold control key and also choose) the .wav file this way on import Encore will bring the audio and video in together on one timeline.
Hope that helps ya! :o)
Eric
Ann Bens
October 1, 2010 at 12:00 pmIf the source is interlaced and the endprocuct is dvd dont make it progressive, just leave it interlaced in Upper Field.
