Activity › Forums › Avid Media Composer › How to do v1/a1 editing with Zoom Multichannel Audio
  • How to do v1/a1 editing with Zoom Multichannel Audio
    Posted by Minh Bui on September 4, 2015 at 11:13 pm
    I’m assisting a short film and the editor likes to do V1/A1 audio editing. In the typical scenario I would get BWF from the sound department with like 4 channels of audio (A1=mono mix, a2=lav, a3=lav, a4= boom). I would created synced subclips that have the full multichannel audio (so it would look like V1/A1-A4).
    Then I would subclip out a separate V1/A1 clip that only has the mono mix on it. That way the editor can edit with the mix track and match back to the full 4 multichannel audio when they need to pull the ISO tracks.
    However, on the zoom files I received it records the multichannel audio each as a separate audio track. So instead of 1 audio file with 4 mono tracks, I get 4 audio files each with a single mono track. The issue is when I try to create the V1/A1 subclip it only tracks back to the one mono track (because that is the original audio track).
    Is there any way that I can prepare these multiple zoom audio files as one wav with multiple tracks? Thanks.
    Minh Bui replied 11 years ago 2 Members · 2 Replies
  • Michael Phillips
    September 5, 2015 at 12:11 am
    The import settings window has a checkbox for combining monophic files to a single clip. Try that. If not you can create poly versions with the free Sound Devices Free Agent.
    Also, you can just select track 1 from the audio only files when syncing (AutoSync) to keep the A1 (or whatever track) and still have the ability to match back to the 4 track audio file.
    Michael
  • Minh Bui
    September 5, 2015 at 12:39 am
    Thanks Michael! The sound devices option totally worked. Wish I had come and asked Creative Cow sooner!
