Activity Forums Apple Final Cut Pro Legacy How to do this effect in fcp?
  • Jerry Hofmann
    July 30, 2010 at 10:01 pm
    It’s a dip to color, and the color used is white. You’ll find the transition in the effects menu in the video transitions. Make it short, say 3-5 frames in duration or so.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Medo Abdo
    July 30, 2010 at 11:58 pm
    thanks for your help! i tried the “dip to color ” but my effect is not like the one on youtube video.. do you think i should speed up the clip before applying the dip to color?
    thanks.
  • Michael Gissing
    July 31, 2010 at 12:17 am
    There is also a speed ramp in the clip that goes with the dip to color. The effect gets really annoying very quickly so I wouldn’t overuse it like this clip does.
  • Tony Brittan
    July 31, 2010 at 4:22 pm
    Try Googling “too much too soon flashframe plugin”. It’s free, works great (for what your tryin to do, you’ll wanna make it 10 frames or less), an I use it quite a bit
    Tony Brittan
    Apple Certified Pro – FCP
    islandshoreproductions.com
