Activity Forums Adobe After Effects How to do THIS effect…
  • How to do THIS effect…
    Posted by Jeremy Donaldson on April 26, 2010 at 2:12 am
    https://www.vimeo.com/11219083
    @ 0:23
    The title jumps around and so fourth.
    Is this an EFFECT? or What do I need to do in order to achieve this effect? Of course I could move position, keyframe, move, etc but is this some sort of shake / wiggle effect?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Steve Roberts replied 16 years, 5 months ago 3 Members · 2 Replies
  • Youssef Sarhan
    April 26, 2010 at 3:04 am
    Just keyframe it.
  • Steve Roberts
    April 26, 2010 at 1:09 pm
    You could apply the wiggle expression to one axis (google wiggle Y axis expression). For the amp variable, you need to select it and pickwhip it to the slider value of an expression control effect which can be applied to the text layer or to a null layer. Then, finally, you animate the slider value from a high value to zero to make the text settle.
    The animated slider effect controls the wiggle expression which controls the Y-position of the text.
    If you want to see the wiggling text more than once over the running time of the comp, you may want to avoid applying the slider to a null — just apply the slider to the same layer as the text, get it right, then dupe the text layer and retype the text if necessary.
