Activity › Forums › Adobe After Effects › How to do a Fake HDR look to a video in AE?
Posted by João Queirós on April 29, 2013 at 2:46 amAnyone know a tip to do this:
Thks
https://www.joaoqueiros.com/uk_resumo.php
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Maxim Chernousov replied 1 year, 11 months ago 5 Members · 5 Replies -
Joseph W. bourke
April 29, 2013 at 3:14 amSure – If you had looked down the page at the replies from people on how it was done, you would have found this:
1. Duplicate the original footage and place it above that layer.
2. Change the Blending option of the duplicate to “Overlay”
3. De-saturate the duplicate layer
4. Invert the duplicate (apply “invert” effect)
5. Add a Gaussian Blur to it
6. Duplicate the original again and place it above the first duplicate
7. Change the blending type of the 2nd duplicate layer to “Linear Light”
8. Lower the opacity of the 2nd duplicate until you get your desired result.While this may only get you close, there are actually multiple ways it could have been done. There are plugins, such as Magic Bullet Looks, which can get you close. But all of these are dependent on a colorist, or After Effects artist, who knows what they’re doing – it’s not just a button you push…
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Tudor “ted” jelescu
April 29, 2013 at 6:47 amI would add one more – make sure that the footage you use is at least 4:2:2 if not 4:4:4. You need all the color information you can get to be able to achieve good results.
If you have a DSLR or a HD camera that records to a 4:2:0 format, then use a HDMI output (or SDI if available) to record to an external device- such as a Atomos Ninja/Samurai in a 4:2:2 10bit format (ProRes or DnXHD)Tudor “Ted” Jelescu
Senior VFX Artist -
John Cuevas
April 29, 2013 at 1:51 pmI can’t remember where I found this, duplicate your layer and change the transfer mode to linear light(sometimes I will duplicate twice and add an overlay transfer also), add this preset and it will get you most of the way to a High Pass look, maybe it will help you out.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
João Queirós
April 29, 2013 at 3:44 pmMany thanks again John Cuevas! I did as you said, and used that preset and the look is very good! Just add and adjustment layer to ajust colours with levels and vibrance! That´s it! Impressive preset, it really makes magic!
Maxim Chernousov
October 4, 2024 at 1:57 pmAs a simple alternative, it is better to use the AlphaPlugins HDR Enhanced plugin to create pseudo-HDR effects on video.
