Activity › Forums › Maxon Cinema 4D › How to Dice Rolling animate
Posted by Chicken Little on June 15, 2007 at 4:46 pmI have a dice ( cube ) but i dont I am affording actuate corretly. I attempted along Xpresso but i dont managed to , like me may I actuate a dice rolling from the manner simpler , detail I go to use a spline linear about to guide the alleyway from the dice.
Brian Jones replied 19 years, 3 months ago 2 Members · 3 Replies -
Brian Jones
June 16, 2007 at 5:02 pmLook at “Using the Mocca ClothHilde to simulate basic dynamics.” on this page https://www.hypa.tv/tims/download.html
or use Dynamics. If you don’t have Dynamics or Mocca it’s tougher but someone may know some other way.
Chicken Little
June 17, 2007 at 6:22 pmno is exactly that than I do necessary , the one to I need is from a activity than I do may I master the dice , in other words , something like with the activity of Hitoshi Akayama film https://www.atomfilms.com/film/dice.jsp I so necessary know I eat I do about to to roller the dice. Thank you.
Brian Jones
June 18, 2007 at 2:19 pmI see. Well his explanation (translated from Japanese to english) here https://translate.google.com/translate?u=https://motion-design.jp/dice.htm
says he was using MEL script to control the direction and speed of the die. Xpresso (maybe it would have to be COFFEE) is the thing alright. Linear travel would be linked to rotation (like a wheel rolling along (that’s an easy script) but for the dice to roll it goes up and down as well as it rolls from flat side to flat side over a corner in-between. So a repeating up and down motion would have to be added to the simple “this much travel means this much rotation” script. I would build it like that start with the rotation then add the vertical component later. Or maybe a better way would be to put the dice in a null and add the vertical to that so it would be easier to roll up and not just along (if you wanted to do the same sort of thing he does).
