Activity › Forums › Adobe Premiere Pro › How to determine color depth of my video
  • How to determine color depth of my video
    Posted by Jeremy Hansen on July 23, 2013 at 8:11 pm
    Hello,
    I’m trying to determine the color depth of my source video file. My DP upgraded his Sony FS700 to shoot at 10-bit color depth in S-Log and shot me over a file to determine if the upgrade worked and if the file was in fact at a 10-bit color depth. I’ve looked around but I don’t see any video information display anywhere that simply tells me the color depth of the source file. Any suggestions?
    – Jeremy
    Shane Ross replied 13 years, 2 months ago 3 Members · 3 Replies
  • Ann Bens
    July 23, 2013 at 8:32 pm
    Mediainfo can do that for you.
    https://mediainfo.sourceforge.net/nl
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Jeremy Hansen
    July 23, 2013 at 8:47 pm
    Hi Ann!
    Thanks for the tip. I bought the app and ran my clip through it, but I don’t see color depth information in there:
    General
    Complete name : /Users/jchproductions/Downloads/SAMURAI_S001_S001_T003.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 26.9 MiB
    Duration : 1s 213ms
    Overall bit rate mode : Variable
    Overall bit rate : 186 Mbps
    Encoded date : UTC 2013-07-23 02:32:47
    Tagged date : UTC 2013-07-23 19:26:15
    Writing library : Apple QuickTime
    ©TSC : 24000
    ©TSZ : 1001
    Video
    Format : ProRes
    Format version : Version 0
    Format profile : High
    Codec ID : apch
    Duration : 1s 126ms
    Bit rate mode : Variable
    Bit rate : 198 Mbps
    Width : 1 888 pixels
    Original width : 1 920 pixels
    Height : 1 062 pixels
    Original height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Scan type : Progressive
    Bits/(Pixel*Frame) : 4.126
    Stream size : 26.6 MiB (99%)
    Writing library : atms
    Language : English
    Tagged date : UTC 2013-07-23 02:32:47
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 1s 213ms
    Bit rate mode : Constant
    Bit rate : 768 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 114 KiB (0%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Duration : 1s 213ms
    Time code of first frame : 00:00:00:00
    Time code settings : Striped
    Language : English
    Am I being dense and just not seeing it?
    Thanks for your time!
  • Shane Ross
    July 23, 2013 at 9:03 pm
    [Jeremy Hansen] “Format : ProRes”
    ProRes is always 10-bit.
    https://documentation.apple.com/en/finalcutpro/professionalformatsandworkflows/index.html#chapter=10%26section=1%26tasks=true
    Shane
    Little Frog Post
